MBREQ
Bulk Data Entry Defines a multibody as a combination of request sets defined via MBREQE and MBREQM.
MBREQ | SID | R | R | R | R4 | R5 | R6 | R7 | |
R8 | R9 | etc |
MBREQ | 3 | 31 | 34 | 35 |
SID | Request set identification
number. (Integer > 0) |
Ri | Request set identification
numbers defined via entry typed enumerated above. The
Ri must be unique. (Integer > 0) |
- Request sets must be selected in the Subcase Information section (REQUEST) if they are to be applied.
