MBREQE
Bulk Data Entry Defines a multibody solver output request to output the results of a set of expressions.
MBREQE | RSID | RID | E | E | E | E | E | E |
MBREQE | 235 | 10 | 20 | 30 | 40 |
RSID | Request set identification
number. (Integer > 0) |
RID | Request identification
number. Request ID must be unique with respect to all other MBREQM and MBREQE cards. (Integer > 0) |
E | ID of
MBVAR. (Integer > 0) |
E, … E | Additional
MBVAR IDs. Default = blank (blank or Integer > 0) |
- The request evaluates the expression at every output step.
- The values are always set to 0, if the expression is not specified.
- Request set will be specified in the subcase definition.
