MBREQM
Bulk Data Entry Defines a multibody solver output request to output displacement, velocity, acceleration, or force with respect to markers.
MBREQM | RSID | RID | TYPE | IMARK | JMARK | RMARK |
MBREQM | 20 | 234 | DISP | 20 | 30 | 10 |
RSID | Request set
identification number. (Integer > 0) |
RID | Request identification
TYPE | Output type:
No default |
IMARK | Marker ID. The output
request is usually of IMARK with respect to
JMARK resolved in
RMARK. (Integer > 0) |
JMARK | Marker ID. If not specified, the results are with respect to global frame. Default = blank; (blank or Integer ≥ 0) |
RMARK | Reference marker ID.
Request ID must be unique with respect to all other MBREQM and MBREQE cards. If not specified, the results are resolved in the global frame. Default = blank; (blank or Integer ≥ 0) |
- Request set will be specified in the subcase definition.
