MBSEQ
Bulk Data Entry Defines the simulation sequence for the multibody solver.
MBSEQ ID SID1 SID2 SID3 etc etc
MBSEQ 9 99 12 43
ID Unique identification number.
(Integer > 0)
SID1, SID2, etc. IDs of the simulation sequence. Valid IDs are:
MBSIM
MBLIN
MBSIMP
MBACT
MBDEACT
(Integer > 0)
  1. Every time an MBSIM card is encountered, a simulation is performed on the multibody model. The initial condition for the next MBSIM will be the ending condition of the current simulation.
  2. This card is represented as a load collector in HyperMesh.
