MBSFRC
Bulk Data Entry Defines a constant scalar load on two grid points.
MBSFRC | SID | G1 | G2 | F |
MBSFRC | 3 | 345 | 346 | 1.0 |
SID | Load set
G1 | Grid point
G2 | Grid point
F | Value of
load (Real) |
- MBSFRC applies a translational action-reaction force along the line of action defined by the line segment connecting G1 and G2.
- The action force is applied to G1 and the reaction force is applied to G2.
- Tensile force is positive.
