MBSIMP
Bulk Data Entry Defines the simulation parameters for subsequent multibody simulation.
MBSIMP | ID | CTOL | IDTOL |
MBSIMP | 99 | 0.001 | 1.0E-8 |
ID | Unique identification
number. (Integer > 0) |
CTOL | Constraint tolerance. Default = 1.0E-10 (Real > 0.0) |
IDTOL | Implicit differentiation
tolerance. Default = 1.0E-6 (Real > 0.0) |
- This card is represented as a load collector in HyperMesh.
