MBSMNT
Bulk Data Entry Defines a constant scalar moment on two gird points along the specified vector.
MBSMNT | SID | G1 | G2 | T | G3/Vx | Vy | Vz |
MBSMNT | 3 | 345 | 346 | 1.0 | 0 | 1.0 | 1.0 |
SID | Load set
G1 | Grid point
G2 | Grid point
T | Value of
moment. (Real) |
G3 | Grid point
identification number to optionally supply
Vx, Vy, and
Vz in conjunction with
G1. (Integer > 0) |
Vx | X component of vector V | |
Vy | Y component of vector V | |
Vz | Z component of vector V |
- MBSMNT applies a scalar action-reaction moment on G1 and G2 along the vector defined by Vx, Vy, and Vz.
- The action moment is applied to G1 and the reaction moment is applied to G2.
- Right hand rule defines the positive moment.
