MBSMNTC
Bulk Data Entry Defines a curve scalar moment on two grid points along the specified vector.
MBSMNTC | SID | G1 | G2 | CVID | G3/Vx | Vy | Vz | ||
INT | EID |
MBSMNTC | 3 | 345 | 346 | 2 | 0 | 1.0 | 1.0 | ||
AKIMA | 1 |
SID | Load set
G1 | Grid point
G2 | Grid point
CVID | Set identification
number of the MBCRV entry that provides the
load vs. independent variable measured in the coordinate system
defined by CID. (Integer > 0) |
G3 | Grid point
identification number to optionally supply
Vx, Vy, and
Vz in conjunction with
G1. (Integer >: 0) |
Vx | X component of vector V | |
Vy | Y component of vector V | |
Vz | Z component of vector V | |
INT | Interpolation type.
EID | Set identification
number of the MBVAR for
the independent variable expression. Default = TIME (Integer ≥ 0 or blank) |
- MBSCMTC applies a scalar action-reaction moment on G1 and G2 along the vector defined by Vx, Vy, and Vz.
- The action moment is applied to G1 and the reaction moment is applied to G2.
- Right hand rule defines the positive moment.
