By using extrusion manufacturing constraints in topology optimization, constant
cross-section designs can be attained for solid models - regardless of the initial mesh,
boundary conditions or loads.
In some cases, it is desirable to produce a design characterized by a constant cross-section
along a given path, particularly for parts manufactured through an extrusion
process.
Extrusion constraints can also be used for the conceptual design study of structures that do not specifically need to be manufactured using an extrusion procedure. Those requirements can be regarded as specific geometric constraints and can be used for any design that desires such characteristics. For instance, it might be desirable to have ribs going through the entire depth of a solid domain.
As with other manufacturing constraints, extrusion constraints can be applied on a component
level, and can be defined in conjunction with Minimum Member Size Control using the DTPL card.
Problem Setup
Extrusion constraints can be applied to domains characterized by non-twisted cross-sections (left
figure) or twisted cross-sections (right figure) by using the
NOTWIST or TWIST parameters respectively in
the ETYP field. The structure is non-twisted when the local
coordinates systems associated with each cross-section, projected onto a reference
plane, remain parallel to each other. Figure 1. Non-Twisted and Twisted Cross-Sections
Define the Extrusion Path
It is necessary to define a 'discrete' extrusion path by entering a series of grids
in the EPATH1 field. The curve between these grids is then
interpolated using parametric splines. The minimum amount of grids depends on the
complexity of the extrusion path. Only two grids are required for a linear path, but
it is recommended to use at least 5-10 grids for more complex curves. Figure 2. Four Grids to Define Extrusion Path
In the example above, four grids are used to define the extrusion path (left figure),
where the path computed by OptiStruct is inaccurate. To
obtain a more accurate approximation, more grids are included in the extrusion path
(right figure).
For twisted cross-sections, a secondary extrusion path needs to be defined in a
similar manner through the EPATH2 field.
Example: Curved Beam
In this example, a curved beam is considered to be a rail over which a vehicle is
moving. Both ends of the beam are simply supported. A point load applied over the
length of the rail as five independent load cases simulates the movement of the
vehicle. The objective is to minimize the sum of the compliances, and the material
volume fraction is constrained at 0.3. The rail should be manufactured through
extrusion. The 13 grids represented as black dots on the right figure define the
extrusion path. Figure 3. Curved Beam
The optimized topologies without and with extrusion constraints are shown in Figure 4. Reanalyzing the final designs without penalty for intermediate
density, the compliances for these two designs are 29.9396 and 37.4377 respectively,
which implies a 20% loss in performance due to extrusion constraints. The extruded
design represents a clean proposal that requires little refinement. On the other
hand, the design obtained without manufacturing constraints may require significant
modifications that could cause efficiency loss in performance. Figure 4. Extrusion Constraints
Example: Stair Shaped Structure
A "stairs" shaped structure is submitted to two lateral pressure loads defined in two separate
subcases. The objective is to minimize the sum of the compliances under both load
cases. The extrusion path is defined as a straight line parallel to the global
Y-axis. The cross-section of the finite elements model along that path is not
constant. Figure 5. Stairs Shape Structure
Clearly, this type of structure is not suitable to be manufactured through an extrusion process.
However, extrusion constraints can be applied to obtain a manufacturable design
characterized by ribs going through the entire depth of the structure. The optimized
design gives a good idea of the layout of the resulting stiffening panels. Figure 6. Resulting Stiffness Panels
Example: Extrusion Constraints
How extrusion constraints can be used to develop common components in different areas
of a structure is illustrated. The extrusion path can be defined through a solid
mesh that is not continuous. Figure 7. Figure 8. Non-continuous Solid Mesh
