MINMAX or MAXMIN
Subcase Information Entry The MINMAX or MAXMIN commands can be used to select normalized response or system identification definitions as the objective function for a "Minmax" or "Maxmin" optimization.
MINMAX = integer
MAXMIN = integer
- Multiple MINMAX entries are allowed and multiple MAXMIN entries are allowed, but a MAXMIN entry cannot appear in the same input file as a MINMAX entry.
- The multiple MINMAX or MAXMIN entries define the same optimization problem.
- Refer to Minmax Objective Function in the User Guide for more information on "Minmax" optimization.
- If the DSYSID entry is
referenced by a MINMAX or a MAXMIN Subcase
Information Entry, the beta method is applied in the optimization as:
Minimize with
(1) - This entry is represented as an optimization objective in HyperMesh.
