MLOAD
Bulk Data Entry Defines a multibody as a linear combination of load sets defined via GRAV, MBFRC, MBFRCC, MBFRCE, MBMNT, MBMNTC, MBMNTE, MBSFRC, MBSFRCC, MBSFRCE, MBSMNT, MBSMNTC, and MBSMNTE.
MLOAD | SID | L1 | L2 | L3 | L4 | L5 | L6 | L7 | |
L8 | L9 | etc |
MLOAD | 3 | 31 | 34 | 35 |
SID | Load set identification number. Must be
selected in the Subcase Information section (MLOAD = SID), if they are to be
applied. (Integer > 0) |
Li | Load set identification numbers defined
via entry typed enumerated above. The Li must be
unique. (Integer > 0) |
- An MLOAD entry may not reference a set identification number defined by another MLOAD entry.
- This card is represented as a load collector in HyperMesh.
