MLOAD
Subcase Information Entry The MLOAD command can be used to select a Multibody load set to be applied in a Multibody problem.
MLOAD = option
- Only one MLOAD entry can be present for each subcase.
- This Subcase Information Entry is only valid when it appears in a Multibody subcase.
- If the SID referenced by the MLOAD Subcase Information Entry matches with the SID defined for an MLOAD Bulk Data Entry, the information on this entry alone is selected. However, if a MLOAD Bulk Data Entry does not have the referenced SID defined, any of the Multibody load entries: GRAV, MBFRC, MBFCC, MBFRCE, MBMNT, MBMNTC, MBMNTE, MBSFRC, MBSFRCC, MBSFRCE, MBSMNT, MBSMNTC, or MBSMNTE which have this SID will be selected.
