MODEL
I/O Options and Subcase Information Entry The MODEL command can be used in the I/O Options section to request output of only a subset of the model and related results for H3D and OUTPUT results files as well as for CMS superelements.
MODEL = elset, gridset, rigidset
Argument Options Description
elset <SID, PLOTEL, ALL, NONE>
Default (analysis run) = ALL
Default (CMS SE creation) = NONE
SID
ID of an element SET. A set of elements that describe the subset of the model for which results and model information is to be output. All GRID and SPOINT associated with these elements will also be output.
PLOTEL
All PLOTELs in the model and their associated GRID will be output.
ALL
All elements in the model and their associated GRID will be output.
NONE
No elements.
gridset <SID, ALL, NONE>
SID
SID of a SET. A set of grids to be added to the subset associated with the preceding elset field.
ALL
All grids.
NONE (Default)
No grids are added to the subset described by the preceding elset field.
rigidset <RIGID/ALL, NORIGID/NONE, SID>
Default (analysis run) =RIGID/ALL
Default (CMS SE creation) = NORIGID/NONE
RIGID/ALL
All rigid elements and their associated GRID will be output.
NORIGID/NONE
No rigid elements will be output.
SID
ID of a rigid element SET. A set of rigid elements that describe the subset of the model for which model information is to be output. All GRID and SPOINT associated with these rigid elements will also be output.
  1. For CMS superelements output in *.h3d format, only the ASET, BSET, or CSET degrees of freedom are output when the MODEL data is not present. When the MODEL data is present, the .h3d file contains the ASET, BSET, or CSET degrees of freedom and what is specified on the MODEL data.
  2. In addition to the results output, the MODEL data controls the portion of the model that is written to the .op2 and .h3d files.
  3. The gridset always contains the ASET, BSET, or CSET grids along with any grids specified on the model data. In addition, all grids associated with the elements in the elset are included in the gridset. The same is true for grids associated with the rigid elements if RIGID is specified.
