MODOUT
Bulk Data Entry Options for displacement and energy results, based on eigenvectors from PFMODE modal participation.
MODOUT | ID | ||||||||
OTYPE | OPTIONS | GROUP |
MODOUT | 3 | ||||||||
DISP | ALL | ||||||||
ESE | ALL | PROP | |||||||
EKE | ALL | COMP |
ID | Identification number.
This can be referenced on the PFMODE I/O Options
Entry. No default (Integer > 0) |
OTYPE | Output type.
No default |
OPTIONS |
GROUP | Corresponding results.
- MODOUT Identification numbers are not unique. You can define multiple MODOUT entries with the same ID.
- Duplicated OTYPE continuation lines are not allowed. Only one of each OTYPE (DISP) is allowed in a particular MODOUT Bulk Data Entry.
