MONITOR
Subcase Information Entry Can be used to activate Nonlinear Displacement Monitoring for a subcase by referencing a corresponding MONITOR Bulk Data Entry.
MONITOR = option
Argument Options Description
option <ID>
No default
ID
Set identification of a MONITOR Bulk Data Entry.
  1. Monitoring results via the MONITOR entry are output to the <filename>.monitor and <filename>_ld.monitor files.
  2. The <filename>.monitor and <filename>_ld.monitor files are output by default for any nonlinear analysis; however, the displacement results for a particular DOF are output only if the MONITOR Bulk Data and Subcase Information Entries are specified.
