MOTION
Bulk Data Entry Defines a multibody as a combination of motion sets defined via MOTNJ, MOTNJC, MOTNJE, MOTNG, MOTNGC, and MOTNGE.
MOTION | SID | M1 | M2 | M3 | M4 | M5 | M6 | M7 | |
M8 | M9 | etc |
MOTION | 3 | 31 | 34 | 35 |
SID | Motion set identification number. Must be
selected in the Subcase Information section (MOTION=
SID), if they are to be
applied. (Integer > 0) |
Mi | Motion set identification numbers defined via
entry typed enumerated above. The
Mi must be unique. (Integer > 0) |
- This card is represented as a load collector in HyperMesh.
