MOTNJG
Bulk Data Entry Defines motion for joint connector JOINTG Bulk Data Entry.
MOTNJG ID
  JID1 DOF VALUE
  JID2 DOF VALUE
  etc.
MOTNJG 3
  2 1 1.0
  3 2 2.0
ID Motion set identification number.
(Integer > 0)
JIDi Identification number of a JOINTG Bulk Data Entry on which the motion is to be applied.
DOF Degree of freedom component number.
No default (1 ≤ Integer ≤ 6)
VALUE
Real
Motion value to be applied on the identified degree of freedom for the specified JOINTG joint. For more information, see the corresponding joint description on the JOINTG entry.
FIXED
The corresponding degrees of freedom of the JOINTG entry are fixed.
No default
  1. The MOTNJG Bulk Data Entry can be referenced in the corresponding MOTNJG Subcase Information Entry.
  2. If a MOTNJG Bulk Data Entry is not referenced in any subcase, then it is not used in the solution.
