NLADAPT
Subcase Information Entry The NLADAPT entry can be used to select the parameters used for Large Displacement Nonlinear Static Analysis, Small Displacement Nonlinear Static Analysis, and Nonlinear Transient Analysis.
NLADAPT = option
Argument Options Description
option <SID>
No default
SID
Set identification of an NLADAPT Bulk Data Entry.
  1. NLADAPT Bulk Data Entries will not be used unless selected in the Subcase Information section.
  2. The NLADAPT command is supported in quasi-static analysis and large displacement nonlinear analysis.
