NLENRG
Bulk Data Entry Defines parameters for energy variables printout for implicit nonlinear static and implicit nonlinear transient analyses.
NLENRG ID PARAMi VALUEi
The following continuation line is optional and can be used to activate printout of energy variables for selected element SETs.
ESET SET1 SET2 etc.
The following continuation line is optional and can be used to activate printout of energy variables for selected contact interfaces.
CONTACT CID1 CID2 etc.
The following continuation line is optional and can be used to activate printout of energy variables for selected (per-property) groups of CGAP/CGAPG elements.
PGAP PGID1 PGID2 etc.
NLENRG 99 FREQ 2
  ESET 1001 1002
CONTACT ALL
PGAP 100 200
ID Each NLENRG Bulk Data Entry must have a unique ID.
No default (Integer > 0)
PARAMi Name of parameter.
VALUEi Value of parameter.
ESET Keyword indicating energy variables are to be printed for selected element SETs.
SETi Element SET identification number.
CONTACT Keyword indicating energy variables are to be printed for selected contact interfaces.
CIDi
ALL
All the contact interfaces.
Integer > 0
Contact interface identification number.
No default
PGAP Keyword indicating energy variables are to be printed for selected CGAP/CGAPG elements.
PGIDi
ALL
All the PGAP properties.
Integer > 0
PGAP property identification number.
No default
PARAMi VALUEi SI Unit Example
FREQ Output frequency in increments.
Default = 1 (Integer > 0)
HG Control for output of HyperGraph data files (*.nlm). 3 4
0
HyperGraph data output is not activated.
1 (Default)
HyperGraph data output is activated for global energy variables.
2
HyperGraph data output is activated for the global energy variables and per-entity energy variables.
  1. The NLENRG Bulk Data Entry is selected by the NLENRG Subcase Information command. In the following comments, filename implies the actual name of the input file or model.
  2. The energy variables are printed into the filename_e.out file for all nonlinear subcases.
  3. HyperGraph data file for the global energy variables, if activated is named as filename_s<n>_e.nlm for each nonlinear subcase; where, <n> denotes the subcase ID.
    HyperGraph data file for the per-entity energy variables, if activated is named as for each entity in each nonlinear subcase:
    • filename_eset<ID>_s<n>_e.nlm
    • filename_cont<ID>_s<n>_e.nlm
    • filename_pgap<ID>_s<n>_e.nlm
    Where,
    <ID>
    Denotes the entity ID
    <n>
    Denotes the subcase ID
    The files *.nlm can be read and plotted by HyperGraph and, a HyperGraph session file named filename_nlm.mvw is created for straightforward plotting of the global energy variables.
  4. For an implicit nonlinear subcase, if NLENRG entry is not defined, the global energy variables are written into a HyperGraph data file (filename_s<n>_e.nlm) for each time increment. However, the output of the filename_e.out file requires the presence of NLENRG Bulk/Subcase Entry pair.
  5. The global energy variables include:
    • • Total strain energy
      • Plastic dissipation energy
      • Hourglass energy
    • Static stabilization energy
    • Contact stabilization energy
  6. The element energy variables include:
      • Hourglass energy
  7. The contact/gap energy variables include:
  8. Implicit nonlinear analysis does not support hourglass elements and so hourglass energy is always zero.
  9. Energy output for implicit nonlinear analysis is only controlled by the NLENRG Bulk/Subcase Entry pair. There is no influence of NLMON or NLOUT entries on the nonlinear energy output. Additionally, energy is always output on-the-fly dynamically during the analysis.
