NLLOAD
I/O Options and Subcase Information Entry The NLLOAD entry can be used to request nonlinear load output for Transient Response Analysis for each time step for all subcases or individual subcases, respectively.
NLLOAD(format)= option
Argument Options Description
format <PUNCH, blank>
PUNCH
Results are output in Nastran punch results format (.pch file).
blank (Default)
Results are output in all active formats for which the result is available.
option <ALL, SID, NONE>
ALL (Default)
Nonlinear loads will be output for all grid points.
SID
Identification number of a set of grid points for which nonlinear loads are output.
NONE
Nonlinear loads will not be output.
  1. Nonlinear loads are output only for Transient Analysis subcases.
