NLOAD
Bulk Data Entry Defines a loading condition for nonlinear problems as a linear combination of load sets defined via NLOAD1.
NLOAD | SID | S | S1 | L1 | S2 | L2 | S3 | L3 | |
S4 | L4 | etc | etc | etc | etc | etc | etc |
NLOAD | 5 | 1.0 | 2.0 | 101 | 2.0 | 102 | 2.0 | 103 | |
-2.0 | 201 |
SID | Load
set identification number. SID
must be unique from all NLOAD1
entries. No default (Integer > 0) |
S | Scale factor. No default (Real) |
Si | Scale factors. No default (Real) |
Li | Load
set identification numbers of NLOAD1. Each
Li must be unique from any other Li on the
same entry. No default (Integer > 0) |
- Dynamic load sets must be selected in the I/O Options or Subcase Information sections with NLOAD=SID.
- The
load vector being defined by this entry is given
by:
(1) - An NLOAD entry may not reference a set identification number defined by another NLOAD entry.
- This card is represented as a load collector in HyperMesh.
