NLOAD
Subcase Information Entry The NLOAD command can be used to select a time dependent load to be applied in Explicit Dynamic Analysis problem.
NLOAD = option
Argument Options Description
option <SID>
No default
SID
Set identification of an NLOAD or NLOAD1 Bulk Data Entry.
  1. NLOAD can only be used in subcases that contain an ANALYSIS=EXPDYN entry.
