NLOUT
Subcase Information Entry The NLOUT entry can be used to select the incremental result output parameters used for Nonlinear Static Analysis and Nonlinear Transient Analysis.
NLOUT = option
Argument Options Description
option <ID >
No default
ID
Set identification of an NLOUT Bulk Data Entry.
  1. NLOUT Bulk Data Entries will not be used unless selected in the Subcase Information section.
