NLPRINT
Bulk Data Entry Controls the printing of certain information to the _nl.out file for nonlinear analysis.
NLPRINT | ID | PARAM1 | VALUE1 | PARAM2 | VALUE2 |
NLPRINT | 99 | CONTCHG | 20 | ELEMDIST | ALL |
ID | Each NLPRINT Bulk Data Entry must have a
unique ID. (Integer > 0) |
PARAMi | Name of parameter. (Character) |
VALUEi | Value of parameter. |
PARAMi | VALUEi (with i=1,2) | SI Unit Example |
CONTCHG | Controls the printing of a list of grids associated with a
change in contact status, to the _nl.out
file. This does not affect the output to the
_nl.h3d file.
ELEMDIST | Controls the printing of distorted elements to the
_nl.out file. This does not affect the
output to the _nl.h3d file.
Default = 10 |
- The NLPRINT Bulk Data Entry is selected in the Subcase Information section.
- This card is optional for nonlinear analysis. It controls the additionally printed information to the _nl.out file for debugging and monitoring purposes, including the list grids with contact change (CONTCHG), or the list of distorted elements that lead to cutback or divergence (ELEMDIST).
- By default, the grid list with contact change is not printed (CONTCHG,OFF). In case of element distortion, only the first 10 elements are printed (ELEMDIST,10).
