NLRESTART
I/O Options and Subcase Information Entry The NLRESTART command can be used in the I/O Options section to indicate the current nonlinear solution sequence is to be restarted from a specified nonlinear subcase.
NLRESTART = n
Argument | Description |
n | Nonlinear SUBCASE ID to be
restarted from in the current nonlinear solution sequence. If n is not given, it will restart from the first nonlinear subcase ending with error in previous run. |
- This command applies only to geometric nonlinear subcases (ANALYSIS = EXPDYN).
- Only one NLRESTART entry can be defined, and it must be above the first subcase.
- NLRESTART is also available in
command line option as
-nlrestart
n or-nlrestart
. If NLRESTART is defined in both Bulk Data and command line option, the former overrides the latter.
