NOISEXYZ
I/O Options and Subcase Information Entry Defines perturbation parameters for all X1, X2, and X3 grid point coordinate values which define the location of the grid points in the model. This entry applies to the X1, X2, and X3 fields of all GRID entries in the model.
NOISEXYZ can be used to check the sensitivity of a particular model to small changes in grid point coordinates.
NOISEXYZ | MAGLMT | RNDSEED |
NOISEXYZ | 1.3 | 1 |
MAGLMT | Defines the Magnitude
Limits of Perturbation for all grid points. This is a maximum real
number value by which the current grid point coordinates can be
increased or decreased. Each coordinate of each GRID is modified by
adding an independent random value in the range
[-MAGLMT, +MAGLMT]. No default (Real > 0) |
RNDSEED | Defines the seed for
random process computing perturbation values, when reproducibility
of results is required. With RNDSEED=0 (or blank)
every time OptiStruct runs, the
perturbation will be different (chosen within the interval
(-MAGLMT, +MAGLMT)), but
when any non-zero value is used for RNDSEED, then
consecutive runs with the same value for RNDSEED
will produce identical perturbations. Default = 0 (Integer ≥ 0) |
- The ECHO I/O Options Entry can be used in conjunction with NOISEXYZ to print the perturbed grid point coordinates to the .out file.
- NOISEXYZ is applied prior to the processing of the CONNECT Bulk Data Entry (if present), which will likely affect the connectivity of parts.
- The following is a perturbation example of a Grid Point
Coordinate:INPUT
GRID,1,0,0.0,0.0,0.0,0 GRID,2,0,10.0,0.0,0.0,0 NOISEXYZ,0.2
ECHOGRID,1,0,6.22070312-2,-6.6479492-2,4.11560059-2,0 GRID,2,0,9.8447753906,-.1767333984,-.188873291,0
