NOLIN3
Bulk Data Entry Defines nonlinear transient forcing functions of the form.
(1)
Pi(t)={S[Xj(t)]A,Xj(t)>00,Xj(t)0
Where, Xj(t) may be a displacement or a velocity at point GJ in the direction of CJ.
NOLIN3 SID GI CI S GJ CJ A
NOLIN3 4 102   -6.1 2 15 -3.5
SID Nonlinear load set identification number.
No default (Integer > 0)
GI Grid or scalar point identification number at which nonlinear load is to be applied.
CI Component number for GI.
No default (1 ≤ Integer ≤ 6; blank or 0, if GI is a scalar point)
S Scale factor.
No default (Real)
GJ Grid or scalar point identification number.
CJ Component number for GJ, GK according to the following table:
A Exponent of the forcing function.
No default (Real)
Type Displacement Velocity
Grid 1 ≤ Integer ≤ 6 11 ≤ Integer ≤ 16
Scalar Blank or 0 Integer = 10
  1. Nonlinear loads must be selected by the Subcase Information data selector NONLINEAR.
  2. Nonlinear loads may not be referenced on a DLOAD entry.
  3. All degrees-of-freedom referenced on NOLIN3 entries must be members of the solution set.
  4. Nonlinear loads may be a function of displacement (Xj=uj) or velocity (Xj=˙uj) . Velocities are denoted by components ten greater than the actual component number; that is the component 11 indicates velocity in the 1 component direction. The velocity is determined by: (2)
    ˙uj,t=uj,tuj,t1Δt
    Where,
    Δt
    Time step interval.
    uj,t1
    Displacement of GJ-CJ for the previous time step.
  5. Use a NOLIN4 entry for the negative range of Xj(t) .
  6. The time step algorithm in transient solution sequences may loose unconditional stability when this load entry is used. In most practical cases, the time step size chosen to reach a certain accuracy is below the stability limit. It is recommended to decrease the time step if results diverge.
