NSGE
Subcase Information Entry The NSGE command can be used to select a non-structural damping set. The selector command must appear before the first SUBCASE statement.
NSGE = option
Argument Options Description
option <SID>
No default
SID
Set identification number of a NSGEADD Bulk Data Entry or, if no NSGEADD Bulk Data Entry exists with this SID, the set identification of NSGE and NSGE1 Bulk Data Entries.
  1. Only one NSGE Subcase Information Entry can be present in the model.
  2. Optimization is currently not supported with non-structural damping.
