Bulk Data Entry Defines non-structural mass as the sum of the sets
listed.
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
NSMADD |
SID |
S1 |
S2 |
S3 |
S4 |
S5 |
S6 |
S7 |
S8 |
S9 |
S10 |
etc. |
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
NSMADD |
4 |
100 |
200 |
Field |
Contents |
SI Unit Example |
SID |
Non-structural mass set
identification number. No default (Integer > 0)
S# |
Identification number of
nonstructural mass sets defined via NSM, NSM1, NSML, and NSML1 entries. No default
(Integer > 0, SID ≠
S#)
- Refer to Non-structural Mass in the User Guide
for more information on the use of this card.
- Non-structural mass in this format must be
selected by the NSM (Subcase Information Entry) Subcase
Information selector.
- No S# may be the
identification number of a non-structural mass set defined by another
NSMADD entry.
- NSMADD entries take
precedence over NSM, NSML,
NSM1 or NSML1 entries. If both have the
same SID, only the NSMADD entry will be
used.
- The value of the non-structural mass does
not change during Topology Optimization.
