OFREQUENCY
I/O Options and Subcase Information Entry The OFREQUENCY command can be used in the I/O Options or Subcase Information sections to request a set of frequencies for output requests for all subcases or individual subcases, respectively.
OFREQUENCY = option
Argument Options Description
option <ALL, SID>
Default = ALL
ALL, blank
Output is for all frequencies.
SID
If a set ID is given, output is only for frequencies listed in that set.
  1. When OFREQUENCY is not present, output is for all frequencies.
  2. The SET definition referenced by the OFREQUENCY card must be a real value set.
  3. The number of solutions selected will always be equal to the number of quantities in the selected set. The closest values will be used.
