OLOAD
I/O Options and Subcase Information Entry Used in the I/O Options or Subcase Information sections to request applied load vector output temperature load output, and applied power output for all subcases or individual subcases, respectively.
OLOAD (format_list,type,spc) = option
Argument Options Description
format <H3D, OPTI, PUNCH, OP2, HDF5 , blank>
H3D
Results are output in Hyper3D format (.h3d file).
OPTI
Results are output in OptiStruct results format (.load file).
PUNCH
Results are output in Nastran punch results format (.pch file).
OP2
Results are output in Nastran output2 format (.op2 file). 7
HDF5
Results are output in the Hierarchical Data format, Version 5 (.h5 file). 8
blank (Default)
Results are output in all active formats for which the result is available.
type <SPARSE, ALL>
Default (OPTI) = SPARSE
Default (H3D, PUNCH, OP2) = ALL
SPARSE
This is only available for the OPTI output format. Output for selected nodes without a component of magnitude 1.0e-10 is not printed.
ALL
Output for all selected nodes is printed.
spc <NOSPC, SPC> Only supported for Linear Static and Nonlinear Static Analysis. It will be ignored, if specified in other subcase types.
NOSPC (Default)
Applied force on SPC degrees of freedom is printed as zero in OLOAD output.
SPC
Applied force on SPC degrees of freedom is retained and printed in OLOAD output.
option <YES, ALL, NO, NONE, SID>
Default = ALL
YES, ALL, blank
Load data is output for all nodes.
NO, NONE
Loads are not output.
SID
If a set ID is given, load data is only output for nodes listed in that set.
  1. When OLOAD command is not present, loads are not output.
  2. Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
  3. Multiple instances of this card are allowed; if instances are conflicting, the last instance dominates.
  4. For optimization, the frequency of output to a given format is controlled by the I/O option OUTPUT.
    In previous versions of OptiStruct, a combination of the I/O Options FORMAT and RESULTS were used; this method is still supported, but not recommended as it does not allow different frequencies for different formats.
  5. Applied Temperature Loads are output in conjunction with the applied load vectors, if OLOAD I/O Options Entry is specified. The temperature loads are output in H3D format. The results are displayed under the "Applied Temperature(s)" label in HyperView.
  6. The SPARSE output type is only available when the OPTI output format is used.
  7. format=OUTPUT2 can also be used to request results to be output in the Nastran output2 format (.op2 file).
  8. The HDF5 output is printed to a .h5 binary results file. The current support of HDF5 output format is:
    1. In case of Linear Static and Normal Modes analysis,
      • The supported element types for element-based results (in .h5 format) are:
        Result Elements Supported
        FORCE/ELFORCE CBAR, CBEAM, CONROD, CTRIA3, CTRIA6, CQUAD4, CQUAD8
        STRESS CROD, CBAR, CBEAM, CONROD, CELAS1, CELAS2, CBUSH, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CTETRA, CHEXA, CPENTA
        STRAIN
      • Corner results are also available for the above results with CQUAD4 and CQUAD8 elements.
    2. In case of Nonlinear Static analysis,
      • The supported element types for STRESS and STRAIN results (in .h5 format) are:
        STRESS,
        STRAIN
        CROD, CELAS1, CBAR, CBEAM, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CHEXA, CPENTA, CTETRA
      • Corner results are also available for CQUAD4 and CQUAD8.
      • DISPLACEMENT, STRESS and STRAIN results are also available on-the-fly during the analysis, if the NLOUT entry is defined in the subcase.
    3. In case of Linear Buckling analysis, only DISPLACEMENT result is available in .h5 format.
  9. Applied Power output is available only for Steady-State Heat Transfer Analysis in H3D and PUNCH files only.
  10. Incremental temperature field output for Nonlinear Analysis is available in H3D files only.
