PANEL
Bulk Data Entry Defines up to four sets of grid points or elements as panels for panel participation output for a frequency response analysis of a coupled fluid-structural model.
PANEL NAME1 SID1 NAME2 SID2 NAME3 SID3 NAME4 SID4
NAME# Panel label.
No default (Character string)
SID# Set identification number for a set of grids or elements.
No default (Integer > 0)
  1. If a set of elements is defined, the panel will consist of all grid points connected to these elements.
