PARAM
Bulk Data Entry Defines values for parameters used during analysis and optimization.
PARAM N V
PARAM COUPMASS YES
Field
Contents
N
Name of Parameter.
V
Value of Parameter.
  1. This card is represented as a control card in HyperMesh.
  2. The available parameters and their descriptions are listed below (click the parameter name for parameter value).
