PARAM, ERPREFDB
Bulk Data Entry Specifies the reference power value used to calculate Equivalent Radiated Power (ERP) in decibels (dB).
Parameter | Values | Description |
ERPREFDB | Real > 0.0 Default = 1.0 |
The Equivalent Radiated
Power (ERP) in decibels can be calculated using
the following equation: Where,
