PARAM, FZERO
Bulk Data Entry Identifies the maximum frequency of a rigid body mode for the Lanczos eigensolver.
Parameter | Values | Description |
FZERO | <Real> Default = 0.1 |
That is all eigenmodes with frequency at or below this cutoff will be regarded as rigid body modes in the inertia relief analysis. |
- To set the rigid body mode cutoff eigenvalue for the AMSES and AMLS eigensolvers, use PARAM, RBMEIG.
