PARAM, HDF5
Bulk Data Entry Controls the output format of the Hierarchical Data result file (HDF5).
By default, the new format (.h5) is available and this parameter
can be used to switch back to the older version (.hdf5), or if
both formats are desired.
Parameter | Values | Description |
HDF5 | <FORM1, FORM2, BOTH> |
- The old format (.hdf5) does not contain finite element model information and hence, requires importing the model file, in addition to importing the result file in a post-processor.
- The new format (.h5) contains both model and result information and hence can be used for post-processing directly.
