PARAM, PRGPST
Bulk Data Entry Outputs AUTOSPC information to the .out file.
Parameter | Values | Description |
PRGPST | < YES, NO, ALL, NONE, <number of DOFs> > | PRGPST
controls the printing of AUTOSPC information to
the .out file.
- If the total number of AUTOSPC dofs is less than 100, all the AUTOSPC dofs will be printed, regardless of the number of dofs specified by the user. When the total number of AUTOSPC dofs is more than 100 and the printing is limited by default value of 100, the user can specify the number of dofs to print more than 100 in .out file.
