PARAM, RSPLICOR
Bulk Data Entry RSPLINE end rotation correction.
Parameter Values Description
RSPLICOR 0, 1, REAL > 1.0 RSPLINE end rotation correction.
0 (Default)
No correction.
1
Two RSPLINE ends have rotation correction.
> 1
Defines cut-off angle. Two RSPLINE ends have rotation correction. If two consecutive RSPLINE sections have an angle larger than the cut-off angle, rotation correction is applied to the shared RESPLINE node.
