Bulk Data Entry The old and new location of moved shell grid
points are printed if SEP1XOVR = 16.
Parameter |
Values |
Description |
SEP1XOVR |
<0,
16> |
- 0 (Default)
- The parameter is not present in the deck.
- 16
- RSSCON
- The old and new location of moved shell grid
= 16, when the RSSCON
shell-to-solid element connector is used. By
default, the moved shell grid points are not
printed, SEP1XOVR =
0.
- RBE2GS
- The internally generated RBE2 elements are
printed when SEP1XOVR=16 when
RBE2GS entries are present in the model. These
internally generated RBE2 elements are printed in
a separate
<filename>.rbe2gs.fem
file.
- This parameter cannot be specified in the input deck without a value.
OptiStruct will error out in this case.
