PARAM, VMOPT
Bulk Data Entry Allows you to prevent the inclusion of the Virtual Mass Matrix in the Regular Mass Matrix for Modal Dynamic Subcases. In such cases, the virtual mass is added after the eigen solution and modes are modified based on the virtual mass matrix.
Parameter | Values | Description |
VMOPT | <Integer = 0, 1, 2> |
- Dry mode output in the .out and .h3d files is available only when PARAM, VMOPT, 2 is specified.
- The mass from MFLUID in the case of PARAM,VMOPT,1 is included in the Grid Point Weight Generator output in the .out file, only if PARAM,VMMASS,YES is also specified.
