PARAM, W3
Bulk Data Entry Converts structural damping to equivalent viscous damping for transient analysis.
Parameter | Values | Description |
W3 | <Real> Default = 0.0 Used in transient analyses to convert structural damping to equivalent viscous damping. |
The damping
matrix
[B]
for transient analysis is assembled from:
[B]=[B1]+ΓΩ3[K]+1Ω4∑ΓE[KE]
Where,
- This parameter can be specified in the Bulk Data section and/or Subcase section. If it is defined in the Subcase section, then it is subcase-specific and this value is only used for this subcase. This is done by defining PARAM, W3, <Real> for each subcase in the Subcase Information section.
- PARAM, W3 is supported with direct transient, modal transient and nonlinear transient analysis types.
- The order of priority is TSTEP or RSPINR/RSPINT entry, Subcase specific PARAM, followed by Bulk Data PARAM.
