PARAM, WTMASS
Bulk Data Entry Converts weights to masses using this multiplier.
Parameter | Values | Description |
WTMASS | < Real > 0.0
> Default = 1.0 |
The WTMASS (Weight-To-MASS) parameter is used as a multiplier for the terms of the structural mass matrix. |
- This parameter only applies to structural elements. It does not apply to either fluid elements nor MFLUID.
- This parameter cannot be applied to superelements (.h3d or .pch) that are read into the model. If the unit of mass is incorrect on the MAT# entries and PARAM, WTMASS is required to update the structural mass matrix, then this should be done in the creation run.
