PBUSHT
Bulk Data Entry Defines property values for a generalized spring and damper structural element.
PBUSHT | PID | TYPE | TID1 | TID2 | TID3 | TID4 | TID5 | TID6 | |
TYPE | TID1 | TID2 | TID3 | TID4 | TID5 | TID6 | |||
etc | etc |
PID | Property identification number. Must match with a
PID of a
PBUSH Bulk Data Entry. No default (Integer > 0) |
TYPE | Identifies what the following six fields referenced. Can be defined in any order
but may only appear once per PBUSH definition. 3
5
6
Or,
Or,
No default |
TID# | A
TABLED# entry identification
number. The type of the referenced table is
defined by the TYPE keyword
given on the same line. The six references on each
line represent the 6 degrees-of-freedom in
sequence from 1 through 6. Default = 0 (Integer ≥ 0) |
- The K, B, GE, and M fields are associated with the same entries on the PBUSH entry.
- PBUSHT may only be referenced by CBUSH elements in the residual structure which do not attach to any omitted degrees-of-freedom.
- TYPE=K/KSCALE,
B/BSCALE,
GE/GESCALE, M/MSCALE
and KMAG/ANGLE are allowed for frequency response
analysis only, while TYPE=KN is allowed only for
nonlinear analysis. In Modal Frequency Response Analysis, the frequency-dependency is only
used in the frequency response part of the solution, not in the modal analysis part of the
solution.
For TYPE=KN, Tension is U > 0 and Compression is U < 0 where U = U(GB) - U(GA) in CBUSH element coordinate system: GA/GB are grid points on CBUSH.
- For backward compatibility with Nastran, if ONLY the dof1 field for the GE line (line where TYPE=GE) is specified on ALL PBUSHT entries and the other dofs for the GE line are blank on ALL PBUSH entries, then a single structural damping table for each PBUSHT applied to all defined dofs on the K line for each PBUSH is assumed. If ANY PBUSHT entry has a dof field other than dof1 for the GE line specified, then the GE fields are considered variable on ALL PBUSH and PBUSHT entries.
- Rotational stiffness values are input based on rotations defined in Radians.
- KMAG/ANGLE
continuation line only affects stiffness (K) and damping
(GE) values.
If ANGLE and KMAG continuation lines on PBUSHT are both defined, then for a particular degree of freedom, after table lookup, the value of frequency-dependent stiffness is equal to KMAG*cos(angle) and GE is equal to tan (ANGLE). Where, KMAG and ANGLE are the magnitude of stiffness and angle values looked up from corresponding dof tables in the KMAG and ANGLE continuation lines. ANGLE is in degrees.
If ANGLE is present, but KMAG continuation line is not defined, then OptiStruct will error out.
- This card is represented as a property in HyperMesh.
