PCOMP
Bulk Data Entry Defines the structure and properties of an n-ply composite laminate material.
PCOMP | PID | Z0 | NSM | SB | FT | TREF | GE | LAM | |
MID1 | T1 | THETA1 | SOUT1 | MID2 | T2 | THETA2 | SOUT2 | ||
MID3 | T3 | THETA3 | SOUT3 | etc. | |||||
DS | NRPT |
PCOMP | 100 | -0.5 | 1.E5 | STRN | 100. | ||||
120 | 0.2 | 0.0 | YES | 120 | 0.6 | 0.0 | NO | ||
120 | 0.2 | 0.0 | YES | ||||||
1.0 |
PID | Unique composite property
identification.
No default (Integer > 0 or <String>) |
Z0 | Real number or character
input (Top/Bottom).
Default = -0.5 * Thick, Thick being the composite total thickness (Real or blank) Character Input 18 |
NSM | Nonstructural mass per
unit area. No default (Real) |
SB | Allowable inter-laminar
shear stress (shear stress in the bonding material). Disregarded if
blank or 0.0. No default (Real ≥ 0.0) |
FT |
Failure theory code. If blank, no failure
calculations are performed. The following failure theory codes are supported:
Default = no failure calculations are performed |
TREF | Reference (stress free)
temperature. 1 Default = 0.0 (Real) |
GE | Damping coefficient. 11
12
LAM |
Laminate option. If blank, all plies must be
specified and all stiffness terms are developed. The following options are
supported:
Default = blank, that is all plies must be specified |
MIDi | Material IDs of individual
plies. The plies are identified by consecutively numbering them from
1 at the bottom layer. The MIDs must refer to
MAT1, MAT2, MAT4, MAT5, or MAT8 Bulk Data Entries. If
MIDi is not specified, default is the last
defined MIDi. Default = last defined MIDi (Integer > 0 or blank, except that MID1 must be specified) |
Ti | Thicknesses of individual
plies. If Ti is not specified, default is the
last defined Ti. Default = last defined Ti (Real ≥ 0.0 or blank, except that T1 must be specified) |
THETAi | Orientation angle, in
degrees, of the longitudinal direction of each ply relative to the
x-axis of the material coordinate system associated with a given
element. If no material coordinate system is specified for the
element, the angle is measured relative to side 1-2 of this
element. Default = 0.0 (Real or blank) |
SOUTi | Stress, Strain and Failure
Index output request for individual plies. 3
4
DS | Design switch. If non-zero
(1.0), the elements associated with this PCOMP
data are included in the topology design volume or space. Default = blank (Real = 1.0 or blank) |
NRPT | Number of repeat laminates
21 Default = blank (Integer > 0 or blank) |
- TREF specified on the PCOMP entry overrides reference temperatures given for individual ply materials. If TREF is not specified (blank) on the PCOMP card, then all the ply materials must have the same reference temperature.
- String based labels allow for easier visual identification of properties, including when being referenced by other cards. (For example, the PID field of elements). For more details, refer to String Label Based Input File in the Bulk Data Input File.
- Stress, Strain and Failure Index output for the PLY is activated by setting SOUT to YES. In addition, the I/O Options CSTRESS, CSTRAIN, and CFAILURE should be defined for Composite Stress, Composite Strain, and Failure Index output, respectively. Failure Index output also requires that the FT and SB fields be defined on the corresponding PCOMPP entry, and that stress/strain allowables (material strengths) on the referenced materials are defined.
- An additional piece of information available with ply results is "failure index for the element," which is the maximum of failure indices for individual plies in this element. Only the plies with SOUTi set to YES are considered in the evaluation of this maximum.
- If all plies specify zero transverse shear
coefficients (G1Z, G2Z on MAT8 card, isotropic G
for MAT1, not available for MAT2), the in-plane shear modulus will be
used to determine transverse shear stiffness of the composite.Note: If just one layer has a nonzero value specified for transverse shear modulus, this substitution is not being performed, and user-specified values are being used for all plies.
- The signs given to stress limits for compression and tension (ST, SC, for MAT1; Xt, Xc, and so on for MAT8) are of no relevance. Absolute values are taken and used in the appropriate context to calculate failure indices.
- For composites with offset
(Z0 ≠ 0.5 * Thickness), correct values of shell stresses
for the bottom and top surfaces of the shell are produced.Note: These shell stresses are calculated using homogenized shell properties, and should be interpreted with caution.
- For composites with offset (Z0 ≠ 0.5 * Thickness) the buckling results will not be correct. This is because the membrane-bending coupling resulting from composite offset is not included in the differential stiffness matrix. Therefore, the preferred method of incorporating offset in buckling analysis is the element offset ZOFFS.
- Element GRID thicknesses cannot be defined for elements that reference PCOMP data.
- Plies are listed from the bottom surface
upwards, in respect to the element's normal direction.
Figure 1. (A) Stacking Sequence for a Non-symmetrical Laminate, (B) Stacking Sequence for a Symmetrical Laminate - If GE is specified on the PCOMP entry as a Real number, it will be used for the element, and the values supplied on material entries for individual plies are ignored. With USEMAT in this field, GE coefficients from ply material data will be used to calculate damping matrices for the composite. These matrices will, in general, be different for membrane, bending, and shear states.
- To obtain the damping coefficient GE, multiply the critical damping ratio C/C0 by 2.0.
- For convenience, element output for the SMEAR and SMCORE options includes both homogenized shell stresses and individual ply stresses. However, because stacking sequence is ignored in these options, individual ply stresses will only be valid in cases of pure membrane deformation.
- Hill's failure theory does not differentiate between compressive and tensile strength. While different values of respective strength limits are accepted, it is still recommended that Xt is set to be equal to Xc, and Yt is set to be equal to Yc when this criteria is used. Xt and Xc are allowable tensile and compressive stresses in the principle x direction of the material. Yt and Yc are allowable tensile and compressive stresses in the principle y direction of the material.
- Failure index calculation according to Maximum Strain Theory is based on mechanical component of strain only, not on total strain. This is because only the mechanical strain contributes to actual damage of the respective ply (pure thermal expansion produces no damaging effects).
- According to the formula, some failure criteria (for example, Tsai-Wu and Hoffman) would produce a negative ply failure, depending on the problem.
- If PARAM, SRCOMPS,YES is added to the input file, strength ratios with respect to designated failure theory are output for composite elements that have failure indices requested.
- The following two formats are permissible
for the Z0 field:
Real Number:
It represents the distance from the shell element reference plane to the bottom surface of the shell (Default = -0.5 * Thick, Thick being the composite total thickness (Real or blank)).
Surface:
Top:
The shell reference plane, the plane defined by the grid points, and the top surface of the shell are coplanar.
This makes the effective "Real" Z0 value equal to the composite total thickness (-1.0 * Thick). See Figure 2.
Figure 2. Top option for Z0Bottom:
The shell reference plane, the plane defined by the grid points, and the bottom surface of the shell are coplanar.
This makes the effective "Real" Z0 value equal to 0. See Figure 3.
Figure 3. Bottom option for Z0Automatic offset control is available for ply thickness (size) optimization and for free-size optimization where the specified offset values are automatically updated, based on thickness changes. For free-size optimization, such an automatic offset is only applicable when Z0=0.0 or BOTTOM.
- The material parameters, Xt, Xc, Yt, Yc, and S on the MAT8 Bulk Data Entry should be specified for failure criteria calculation.
- Small Displacement and Large Displacement Nonlinear Static Analyses are supported with Composites using PCOMP, PCOMPP, and PCOMPG entries.
- The repeat laminates are added to the bottom of the current laminate. Output for repeat laminates are supported in OPTI, H3D, and PUNCH formats.
- This card is represented as a property in HyperMesh.
