PELASFX
Bulk Data Entry Used to define the stiffness and stress coefficient of a scalar elastic element (spring) by means of the CELAS1 or CELAS3 entry.
This property is not affected by translational and rotational stiffness limits specified using PARAM,ELASSTIF.
PELASFX | PID | K | GE | S | PID | K | GE | S |
PELASFX | 7 | 4.29 | 7.92 | 27 | 2.17 |
PID | Unique scalar elastic property identification
number. No default (Integer > 0) |
K | Elastic property value. No default (Real) |
GE | Damping coefficient. To obtain the damping coefficient GE,
multiply the critical damping ratio,
C/C0C/C0
, by 2. GE is ignored in transient analysis, if PARAM, W4 is not specified. Default = 0.0 (Real) |
S | Stress coefficient. Default = 0.0 (Real) |
- Be careful using negative spring values.
- One or two elastic spring properties may be defined on a single entry.
- The
element force of a spring is calculated from the equation:
(1) Where,f=k*(u1−u2)f=k*(u1−u2)- kk
- Stiffness coefficient for the scalar element.
Element stresses are calculated from the equation:(2) Where, SS is the stress coefficient as defined above.s=S*fs=S*f - This card is represented as a property in HyperMesh.
