PFPATH
Bulk Data Entry Defines a one-step transfer path analysis.
PFPATH | SID | CONPT | RID | RTYPE | CONEL | CONREL | CONVOL |
PFPATH | 10 | 11 | 12 | DISP | 18 | 23 |
Argument | Options | Description |
SID | <INTEGER> |
CONPT | <INTEGER> No default |
RID | <INTEGER> No default |
RPTYPE | DISP/VELO/ACCE Default = DISP |
Criterion for the type of the response; the response type corresponding to a structural degree of freedom could be displacement, velocity or acceleration. |
CONEL | <INTEGER> Default = blank |
CONREL | <INTEGER> Default = blank |
If CONREL is specified in the 7th entry, the RIGID element IDs must be unique. |
CONVOL | <INTEGER> Default = blank |
- There can be multiple PFPATH cards with the same SID. However, the connection points should be the same across all the PFPATH entries.
- If CONEL and/or CONREL are specified, the set should consist of all the elements outside the control volume connected to the connection GRID's in CONPT.
- If CONVOL is not specified, OptiStruct will export a file called, <filename>_outsidecv.fem, which contains a list of all GRID's outside the control volume. This file can be imported into HyperMesh to visualize the grids outside the control volume.
