PHFSHL
Bulk Data Entry Defines the thickness, material, blank holder, binder and Forming Limit Curve references for a shell property in a one-step stamping simulation.
PHFSHL PID MID T BHID       FLDID
PHFSHL 1 1 0.01 6       2
PID Unique shell element property identification number.
No default (Integer > 0)
MID Material identification number of a MATHF entry.
T Thickness
No default (Real > 0.0)
BHID Blank holder ID referring to a BLKHDF entry.
No default (Integer > 0 or blank)
FLDID User-defined Forming Limit Curve identification number referring to FLDATA entry.
  1. This entry is only valid with an @ HyperForm statement in the first line of the input file.
  2. All shell element property entries must have unique identification numbers.
  3. PHFSHL is referenced by CTRIA3 and CQUAD4 entries.
