PLOAD2
Bulk Data Entry Defines a uniform static pressure load applied to two-dimensional elements, or a SET of such elements.
Only QUAD4 or TRIA3 elements may have a pressure load applied to them via this entry. It can also be used to define the EXCITEID field (Amplitude "A") of dynamic loads in RLOAD1, RLOAD2, TLOAD1 and TLOAD2 Bulk Data Entries.
PLOAD2 SID P EID/
ELSETID
EID/
ELSETID
EID/
ELSETID
EID/
ELSETID
EID/
ELSETID
EID/
ELSETID
  ELSET
PLOAD2 21 -3.6   4 16   2
Alternate Format and Example
PLOAD2 SID P EID1 THRU EID2 blank blank blank
PLOAD2 1 30.4 16 THRU 48
SID Load set identification number.
(Integer > 0)
P Pressure value.
(Real ≠ 0)
EID/ELSETID, EID1, EID2 Element identification number, or if the ELSET continuation line is specified, an identification of a SET of elements.
At least one positive EID/ELSETID must be present on each PLOAD2 entry.
EID
Must be 0 or blank for omitted entries.
The allowed type is (Integer > 0; EID1 < EID2.
ELSETID
The allowed types are Integer > 0 or <String>.
Where, <String> specifies a user-defined string label for the set. 5
ELSET Flag which indicates that the EID/ELSETID field is identified as a SET of elements at which the loads are applied.
  1. If the alternate form is used, all elements EID1 through EID2 must be two-dimensional.
  2. The direction of the pressure is computed according to the right-hand rule using the grid point sequence specified on the element entry. Refer to the PLOAD entry.
  3. All elements referenced must exist.
  4. Continuations are not allowed.
  5. String based labels allow for easier visual identification of sets, including when being referenced by other cards. For more details, refer to String Label Based Input File in the Bulk Data Input File.
  6. This card is represented as a pressure load in HyperMesh.
