PLOTEL4
Bulk Data Entry Defines a four-noded, two-dimensional dummy element for use in plotting.
PLOTEL4 EID G1 G2 G3 G4
PLOTEL4 29 35 16 22 23
EID Unique element identification number. Unique with respect to all other element identification numbers.
No default (Integer > 0)
G1, G2, G3, G4 Grid point identification numbers of connection points.
No default (Integer > 0; G1G2G3G4)
  1. This element is not used in the model during any of the solution phases of a problem. It is used to simplify the plotting of large structures.
  2. This card is represented as a quad4 element in HyperMesh.
