PLOTEL
Bulk Data Entry Defines a one-dimensional dummy element for use in plotting.
PLOTEL EID G1 G2
PLOTEL 29 35 16
EID Unique element identification number. Unique with respect to all other element identification numbers.
No default (Integer > 0)
G1, G2 Grid point identification numbers of connection points.
No default (Integer > 0; G1G2)
  1. This element is not used in the model during any of the solution phases of a problem. It is used to simplify the plotting of structures with large numbers of collinear grid points, where the plotting of each grid point along with the elements connecting them would result in a confusing plot.
  2. Only one PLOTEL element may be defined on a single entry.
  3. This card is represented as a plot element in HyperMesh.
